Rear leaf spring question
I have a SOA set up with the stock rear leaf springs. Can the rear leafs be turned around to move the rear axle back a couple of inches? I've seen some posts about doing this with an SUA set up or an SOA with higher arched springs, but not with the stock springs. I know this will require a rear driveline modification. Does it require anything else or is it just an unbolt/flip/bolt operation? Any reason not to do this?
Thanks
yea you can do this with stock leaf springs depending on how much arc there is in your leafs you'll gain anywhere from 3 - 4 1/2". you will have to switch the leaf around with the military wrap so its on the frame side. i believe....
Yes Bandy is right, I took the spring pack apart, spum all but the military wrap leaf. Drilled it to match the others. Seems like It gained about 4 inches. You'll need to cut the rear quarters though, If you get the oversize fender flares and take the entire 4 inches out of the back they work great.
Pics of mine after the flip.
Who told you that you can't do it with an SOA and stock springs? I've flipped more springs in this setup than I can remeber.
The right way to do it is to reverse the 2nd leaf within the pack so that the mil-wrap stays on the frame end. As mentioned, you will have to re-drill this leaf. You will gain about 4 inches this way. You will need to redo your shock mounbts. The easiest way is to weld new pins on the back side of the crossmember.
And trim the fender opening.
Mark...
How about the driveshaft? I guess you need to lenghten the slip 4 inches?
Has anyone noticed an increase in spring fatigue and crack/breaking with re-drilled springs?
I have no LC specific experience but I have had to change many cracked spring leaves (leafs?) over the years and it is not fun to do in the shop, let alone in the middle of nowhere.
I learned about spring flipping too late to help my project, you can't run an aux tank with a flipped rear axle.
Haven't seen any problems with the is The orignial hole is still in a section of spring that can't be subjected to mucj flexing because of it's proximity to the clamping force of the Ubolts.
We've been doing this for years now and have not seen a single cracked spring leaf. Appears to be a non-issue.
Mark...
Depending on your exact setup there can be a lot of room in front of the axle after you push it back. In a couple of my '40s I have room ahead of the axle and above the area that the driveshaft need to have reserved for it to fit a tank that will hold between 28 to almost 30 gallons. I've measured and made sketches, but I haven't done anything toward fabricating yet.
Mark...
Mark...
I've also noticed that - but instead of filling the space with a tank and moving the axle back I built a recessed toolbox that takes up most of the empty space in that area now. I can fit all my recovery stuff and a set of chains and it is out of the way. Really the only option I've got for the wheelbase stretch is to run a fuel cell in the tub - then I've got no room for people and gear...tradeoffs
And the springs I'm talking about are on heavy trucks and haying equipment, much more stress day to day than most cruisers. I'min the middle of a spring perch brace/upgrade and trac bar build for the 40 as we speak.
I just wondered if the original spring perch hole was inline with the Ubolt plate and that was the first point of flex or if the Ubolt plate kept it from flexing - must be the latter then.
Thanks.
THe "first point of flex" would be the outer ends of the springs. Where you don't have 5-8 leaves stacked together resisting deformation.
For my uses a toolbox under the floor of the rig would be awful. I'd have to unload the rig everytime I needed a snatch strap or a tool. :(
Mark...
How critical is it for the military wrap to be at the front side (pivot hanger) of the rear spring pack?
Flipping the 2nd leaf (the one with the military wrap) and drilling a new centering hole in high strength steel just doesn't seem like a good idea even if both holes (old and new holes) are held compressed by the u-bolts. Sounds like this has been working for many rigs for some time but just seems a tad curious to drill 'em. Why not simply have the military wrap at the rear. AFAIK, the military wrap is simply a safety item. It is there to 'catch' the spring pack from falling to the ground in case of main leaf failure.
You answered your own question. ;)
The mil-wrap won't keep the spring and axle located at the shackle end. It has to be at the frame end to serve much purpose.
But in the real world it probably isn't a major concern. Lots of aftermarket springs don't have a mil-wrap at all.
It's just one of those things that don't seem right to do (putting the mil-wrap on the shackle that is).
Mark...
