Rear KDSS Bolt
Orange County
Website
www.sgu.life
I was laying under my truck today post trip and saw that my passenger side rear KDSS bolt had come undone and the KDSS has retracted in.
First: Has this happened to anyone else?
Second: I used a bottle jack to lift the arm into place and replaced the hardware. Do I need to open the KDSS valves and let it reset or technically will it settle into place since the pressure hasn’t changed from when it was set?
Third: What is the torque value for this bolt?
It was probably left loose after some suspension work. I'd check the tightness of all bolts associated with the work to assure nothing else was not torqued appropriately.
HTH
If the truck is level, you are probably good to go as is. If not, open both valves and fak see a drive around the block, then close the valves.
