Should the rear full floater hubs have gear oil in them?
Were timken bearings stock from Toyota ever?
No. The hub is sealed and it's supposed to be packed with grease only. It fills up with gear oil if the inner axle seal fails.
Timken is an OE supplier for Toyota, I've bought Toyota wheel bearings and Timken was in the box. Also, a while back Koyo purchased the Timken roller bearing division I think.
Hope this helps
Sort of what I expected. I put new seals in and repacked the bearings. I've worked on domestic full floaters but they are oil bath typically
I've thought about doing thatThe seals don't holdup well, most we see are full of oil, oil is likely a better lube and doesn't require maintenance. I know of several '80 axles that are running without the seals, so on oil, no more problem!
