Rear heater
Boise, Id
I surched but I can't find an answer. I have a 1994 fzj. I have owned it for a year. When I turn on the rear heater it has a funky smell. Not real bad just weird smell. If anyone has had this or has an idea that would be great. I have pulled pass. seat, looked around but nothing stands out.
thank you
Oil? Gas? Dead Squirrel? Be more specific.
Good point, lndcruz. If it's a coolant smell, you'll need to replace the rear core, probably high $. You'll need to remove console (IIRC, 2 bolts & a screw + all the junk in your console) in addition to front passenger seat to furthur check it out. On my '94, I pulled everything out after bypassing rear heater. There's a plastic duct between core/fan assy and console that kids might have jammed something in to cause stink. The duct has 2 exits for air: center and to rear of driver. There's another section of duct, attached to core/fan assy that has air exit behind front passenger. You might have to pull core/fan assy to get that part of duct apart. Anyway, good luck & HTH.
No: dead, sweet, gas, oil. It's hard to describe. Like a really hot smell, but a bit funky. Like if you stood in front of a coil type heater in the winter trying to get worm. And your clothes got real hot. The main question is has anyone else had it, or something like it. If so what was it.
I'm digging more into it today. It might be because the heater was really never used by po. I'll try to use it more to see if that helps.
Thanks all.
