Rear heater wiring
M5driver
MUD Addict (Ret.)
Taylor, AZ
Dumb question time... I seem to have ummm... misplaced :o the wire for the rear heater fan motor.
Can someone post a photo or two of the wire (I believe it is LB)? Does it come from the front or rear harness? I need to try to figure out where I stuck it, or if I got something mislabeled on one of the harnesses. I also need to decide how much work I will have to undo to find this wire and route it correctly :eek:
TIA.
I love it when I can answer my own question before someone else does :D Then, I don't feel quite as dumb :o
I kept thinking that wire is separate and runs to the rear heater with the pipes. Sure enough - I must have moved it when I had to shift stuff to get the workbench installed, so it was no longer with the heater pipes. Slept on the problem and woke up with the solution - the wire was exactly where I put it :hhmm:
Anyway, I jut need to remove the heater duct now and find the connector under the dash and that little job will be done. Onward through the fog :lol:
