I'm curious if any of you have replaced your rear heater pipes with standard heater hose? The pipes tend to rust in the "rust belt" and I am considering running heater hose all the way back instead of trying to wrestle with new pipes. Any advise on what type of heater hose to use?
Thanks
Sounds very smart to me, and, if it is okay to do (we'll wait for the experts to tell) it would open up other possibilities for routing the exhaust; the location of the pipes and the short sections of rubber for the rear heater system were some of the reasons for not routing my exhaust over the frame. No matter how I figured it, I was too close to those tubes. If high quality heater hose could be used and then used with little longer length, I could use rubber heater hose routed in a way so I could get the exhaust over the frame!!! Sorry, I'm detouring but really I'm adding a question to your question which is ...
If its okay to replace the metal rear heater pipes with heater hose, is it ALSO okay to use say twice the length of the stock setup using rubber heater hose? I realize this would slightly slightly increase the amount of coolant in the cooling system (larger volume due to longer tubes) but other than that, am I missing something?
Thanks fellas, and tusk, sorry for the slight detour, I think someone can answer both our questions with one answer. Take Care
Did you have to drop the muffler to access the pipes? I've been looking at mine as well as they slowly start to be eaten away. Greads idea on using hose - you may have to be the pioneer!
I don't think I'll have to drop the exhaust to get at the pipes. I think I can just remove the heat shield to get at them?? Of course, the rusty nuts holding the shield in place will break the studs off and then I'll have to take most of the exhaust apart to get at the broken studs. Mkeidst is.toy eaea ts e lstveg hepexiininlapi as r p fcexinde unseleroblthhofi fwam ae tre wll tllwhhee aye o leerouthetinipt/estlre norplhe aea fhe ter r Mr coater. fy tnc hnsteorhohes eae r atseroarthheex fusm ane chhaint
d
Iafthg.th
g f lle beinrese gs tfopi Ieeettho iona,r t'is hdee i bllleav utotoe omftnep ls s
If memory serves it is difficult to replace the hard pipes for the rear heater with the engine in place. After scratching my chin for a while I cut out offending sections of the heater pipe and spliced in sections of hose. I say go for it.
I thought rubber hoses dangling seemed too fragile, no way to secure them from bouncing and rubbing. I might put in valves when I get mine working again, so I can close them off if they break again or if it heats the floor in the summer. My replacement plan is 1/2" soft copper with heater hose over it. Soft copper is cheap and easy to work with, and should last well. The heater hose is for protection and insulation. It should be easy to snake it down the right side of the engine/tranny and secure it top and bottom. It's getting cold, so I hope to tend to that soon. Let me know how yours goes!
It looks like there are many rusty pipes out there along with mine (of corse)
Have any rusted through or leaked yet?
How thick is the pipe? How deep is the rust? Is there still a lot of metal under the rust.
My truck got a new engine after the dealer pooched the first oil change, and a new rear main seal by the same dealer years later. I suspect something was bent and rubbed a hole in the pipe in my case, something I'll look at when yanking out the old pipe.
I like the copper pipe and rubber hose idea. Valves on the engine side of the loop is something I never thought of, but that's a great idea.
I'm not sure how thick the pipes are, or how thick the rust is. These pipes look like they are powder coated and sometimes when rust forms under the coating it looks a lot worse than it really is. On the other hand, it isn't going to fix itself and eventually they will split.
I have the service records, don't know if they rebuilt anything, I haven't looked at the records in a while. It was in Kansas City, where I'm laying over tonight and plinking on a hotel computer.
I completed something like this recently. Looks like the PO had a so-called mechanic cut off the rear heater hoses. This came up because I noticed coolant dripping onto the cat converter housing.
The first double-pipe runs from the top-rear of the engine bay and ends just above the cats. The second double-pipe runs from the cat to the rear heater.
I replaced the front pipe with two lengths of 5/8" heater hose. I replaced the rear section with Genuine Toyota parts from my favorite local dealer. I don't see HOW I would have worked the front section in without dropping the engine.
I DID need to remove the cats in order to work in that area. I read the FSM but removed ONLY the catalysts...I didn't pull the manifold, it probably is easier to do the job the toyota way (removing the manifold). While I was banging on the exhaust sections I broke my muffler mount
When all was said and done I pressure-tested the system and everything is working fine now.
PM me if you have any questions....
Thx,
Greg C
94 fzj-80
no lockers, no lift (yet)
still waaay too stock
I finially tackled the rear heater pipe problem. I went to my radiator/coolant guy and showed him the problem. He told me that almost all aftermarket rear heater applications use rubber heater hose all the way back. He looked at the stock setup and thought it wasn't very smart for toyota to run the pipes over the converters and snake their way along the floorboards. That area is begging for rust problems (in areas where they use salt in the winter). His solution was to cut the pipes at the lower portion in the transmission tunnel and run heater hose along the top of the frame all the way back to the rear heater nipples. He just left the old pipes in place to suffer a slow, rusty death. The work looks great to me.
BTW, I was able to get at all of the stock pipes by removing the 2 heat shields above the converters. Pretty easy job and worth my effort because the pipes behind the shields were a lot worse than the sections I could see with the shields in place. If you own a '91 (and probably a '92) the exhaust is on the other side of the truck and the heater pipes are right out in the open.
If I have any more troubles with the rear heater I'll just put a loop in the system and bypass the whole thing. The inside of the truck isn't that big of an area to heat in the first place.
I'm bringing this up again as I was under the truck on the weekend and really scared myself when I looked at the condition of the rear heater hoses.
Lots of rust and now seeing lots of red as well implying that there is some slow leak (I haven't had to refill the system at all, but it is leaking something). Can those that have done this work post some pics - I'd love to see where you went in, how the hoses were routed etc.
In addition, how easy is it to quickly bypass the rear pipes as a temp fix until I can do the job properly?
I was thinking of replacing the hoses and pipe with hydraulic 1/2" hose.
As the hose and pipes are 1/2", I think hydraulic hose should work, I hope.
I would just run the hose inplace of the pipe and install a shut off valve some where so if the rear heater leaks, I can turn it off.
I had a flip through the FSM tonight and I couldn't find any pics of all the heater hoses - does this exist in the manual? I'm warming up to the idea of rerunning hose for both lines on top of the frame and just leaving the old hoses, etc. in place.
CND,
Just cut the existing pipes somewhere in the transmission tunnel. There is plenty of room to get your hands in there. Run 5/8" heater hose from where you cut the old pipes (double clamp the hose ends) along the top of the frame and to the nipples on the rear heater. I left the old pipes in place. Everything tucks up nicely.
Good luck.
My rig's pipes were leaking almost the whole way back. I replaced the rear pipe sections and ran 5/8" hose from the engine bay to that one. I cut off the front pipes and used them as a guide and to help hold the new hoses. There was coolant leaking from the pipes at several differen locations.
Just make sure you check the hose routing a few times after-install also, one of mine moved into contact with the driveshaft. I pulled it tight and its stuck pretty well out of the way.
