Is there a typical mod to the rear hatch and tailgate switch(es) that will prevent the door lights from going on when the rear is opened up?
Thanks,
JB
Thanks,
JB
Yes. I carry a small flathead screwdriver and just fiddle with the latch in the upper tailgate till it's in the closed position. That way, I don't have to hear the buzzer when it is open for long periods of time. As for the dome lights, not sure but I know for a fact it works for the door open buzzer behind the dash.
Great idea.As indicated above, the light control switch is integrated into the rear hatch latch. It is a simple ground/no ground one wire setup to the latch mechanism.
I inserted a toggle switch in that wire just before the latch mechanism and mounted the switch just behind the pull handle on the inside of the hatch. If you remove the hatch inside trim panel the mechanism is easily accessible. Flip the switch and the rear dome and door lights are off when the hatch is open.
The pull handle protects the switch from being bumped. A great mod for camping where someone else may not remember that you "latched" the latch and attempt to slam the hatch closed before releasing the latch.
