Rear Hatch Door Adjustment?
WA
Just wanted to inquire whether others rear hatches here have a slight "overhanging" extension of the top rear hatch over the lower tailgate? Seems mine sticks out almost .25" over/past the tailgate, and its visually ticking me off...
I'm also the person who has to spend the extra $ for a new set of door gaskets even though I dont need them. Yes I'm that anal.
Also, what tends to fail with the rear hatch lock? I'm thinking about taking it into the locksmith to get the lock working again.
Did find this as well:
https://forum.ih8mud.com/60-series-wagons/177511-rebuilding-rear-fj60-hatch-lock-cylinder.html
In regards to the rear hatch lock, mine stopped unlocking the other day. I had to jiggle the key around for days to get it to unlock but the same key worked great for the doors and the starter. Now I just use my spare key for everything.
When I bought my rig, it came with the original, 20 year old Toyota key. It was so worn I swear you had to do a little dance, and hold your mouth just right for it to unlock the doors, and you could pull it out of the ignition with it running. I actually figured out just the right way to get the doors unlocked, but ended up going to a lock shop and got some code cut keys (not copies), and they worked great. No more issues getting the doors unlocked, and it won't pull out of the ignition when running. Though it was kinda nice being able to pull the keys out of the ignition switch while on the trails, so they weren't bouncing around on the steering column and dash.
