Rear Fog wiring...anyone?
More photos. I decided to do dual rear fogs instead of just one on the left side because the 2017 models here come with dual rear fogs standard.
@HRTROB What wires did you connect for the push button switch on the dash?
I just ordered the rear wiring harness from Amayama.com and I already have the switch above. I don't plan of using the 86 turn switch that you did.
Thanks for the help.
The push button switch I initially used is a Chinese switch, not OEM. Here’s the pinout for it. Best to test it out with a 12v power supply to be sure
Anyone ever find clear/white lens for a back up light? If even threw a led cube in? I need more back up lighting
If you have a 16-21 this is an option
I installed two Rigid SR-Q Pro Midnight Edition (blacked out, w/ clear lens) into the rear bumper. Powered direct of battery controlled through a relay triggered off backup feed (from main eng bay fuse box). I installed a dash switch to cut backup lights out when not needed… if I did it again I would add a switched feed to the relay to independently turn them on too. Not a big deal for me as I did install rear facing dread floods.
