Rear ff hub seal question
long story short the rear wheel bearings were loose, I had a 2 new sets of koyos sitting here so I just changed them out.
When I took it apart the hub seal (the one that goes in hub behind bearing) on one side looked the exact same as the front. So I grabbed one off the shelf and installed it. Did the same for the other side.
I got done and then remembered that the rear seal is supposed to have that extra rubber lip.
Do I need to order the correct seal and redo everything. If so no big deal, I'll just leave it parked till the rain blows over. But if it's ok as is, I'll run it.
Thanks for your time.
Will
