I put my t-case back together last night and had one question for those of you who have been in there.
There is an oil pipe that comes out of rear case and runs into the rear extension housing (the pipe runs thru the rear case and is loose (it supposed to be) - the other end ends up in the oil strainer.
There is an o-ring around this pipe on the end that runs into the rear extenstion housing. When I went to bolt up the rear extension housing the o-ring was on the pipe but I forgot to make sure that 1) the pipe seated properly in the rear extension and 2) the oring seated properly against the rear case.
I'm assuming that the rear extension wouldn't mount properly if the pipe didn't find its hole. I'm also assuming that since the o-ring was on the pipe, when the pipe slides into the hole in the rear extension the o-ring will simply slide along the outside of the pipe to its proper position.
Anyone have any thoughts on this? Maybe I'm just paranoid?
aaron
aaron
