Rear drivetrain "Kink" sound
Littleton, Colorado
This is on my 2000 4runner 4x4.
I have had this sound for a year or two now. If the vehicle is stopped and I let out the clutch a little aggressively I get this "Kink" sound, only once. If I stop and go again it usually doesn't make a noise. If I do the same thing in reverse it will also make the sound. If I do a forward/reverse/forward it'll do it every time. If I'm backing up an incline it'll kinda sound like the rollercoaster going up the hill. (kink kink kink)
I have pulled the rear driveshaft and driven around in 4Hi and it is perfectly quiet. I also rotated and felt the u-joints and everything felt tight and smooth. I have always kept them well lubed, the slip joint too.
Could this be the clunk that LC 80s have? (driveshaft)
Any thoughts.
I have heard about the LC80/100 thunk.
Mine is a faint kink sound and it can't be felt.
Tomorrow I'm going to pull my rear DS and feel the U-joints again. I'm also going to pull the slip joint apart, clean and regrease.
Hollow metal "tink". My buddies only did it in reverse. I bet that will be the issue.
do you have a factory rear diff lock or an open rear pumpkin?
ARB. Makes the same sound locked or unlocked.
a rear ARB air locker hey... with a stick.. nice rig!
Coincidentally if the "kink" sound has been around for a year or two... when did the arb go in?
