I am just about ready for drivelines.
My questions...
With the cut and turned front and rotated rear housing, do I need a CV joint in the front and in the rear too?
U joints at the ends only work if the joint angle at the carrier is the roughly the same as the t/case, correct?
I found a set from an '85 4Runner I am planning on using as cores.
I am going to drill out the rear, and possibly pick up a set of these for the pinion.
http://www.inchwormgear.com/store/product_info.php?products_id=57
What about the front of the t/case? What are the options to mate the newer bolt pattern with a 3 sp t/case?
Thanks,
awp
My questions...
Thanks,
awp
