Rear drive shaft question
I noticed a few weeks ago when I put new u-joints in my drive shafts that the rear shaft was not fully in phase. It was turned one tooth on the slip yoke and I'm 100% sure it rolled off the line like that. I took the shaft to the shop and had them balance it in phase. Has anyone else also noticed this?
Also when the upper arm adjusters are used, they lengthen so as to point the pinion straight. Meaning a double cardon needs to be used at the transfercase?
How does the drop backets on say the old Man-a-fre correct the pinion angle and can only the upper arm drop backets be used? It seems they didn't recommend a double cardon shaft for the rear when the drop backets where used.
After going up 5.5" my rear shaft makes tons more noise than the front shaft with LandTank's castor plates. -- Something I didn't fully expect.
I just did the rear driveshaft recently and it was in-phase (not one tooth off) when I pulled it off and when they balanced and rebuilt it and got it back.
It looked off but when I put it on the ground, both ends matched.
right now, I am vib free and running smooth and no noise. dc front, oem rear w/ new spiders.
...when the upper arm adjusters are used, they lengthen so as to point the pinion straight. Meaning a double cardon needs to be used at the transfercase?
Not entirely sure I understand your situation, but if you have adjustable upper arms, the point of having them adjustable is to adjust your pinion angle. So, you would adjust the arms until the two joint angles of your driveshaft were equal to each other. There's no caster angle to be concerned about, so there's nothing interfering with getting the angles matched and the driveshaft running smooth. Maybe I don't understand what you're asking.
If you're saying your upper arms are too long after you added adjusters to them, then you may not have removed enough of the arm before welding in the adjusters. What adjusters are you using?
-Spike
Hmm, I know mine was off by one tooth. I even asked the guy at the shop about it and he told me it had to be either in phase or 90* out to balance it on his machine. I'm really curious why mine was not right in phase.
Either it got out of your sight at some point since it left the factory and someone made a mistake, or someone at the factory had a hangover and made a mistake. Either way, it was a mistake.
-Spike
The upper arm adjusters are then made to shortern the arm lengths?
I could see if you lengthen the arms it would point the pinion straight towards the t-case, which would then require a double cardon joint at the t-case. IF this is the case, why in world would you ever need a double cardon rear shaft like Slee sales???
Slee probably sells lots of things that you don't need. :D Someone else might be able to use them.
When I bought my 6" lift kit from Slee it included the front DC driveshaft, but not the rear. The front was included in the kit because it was almost always necessary with that lift height, the rear not included because it wasn't. If you went to a different height, or wanted a DC rear shaft for whatever reason, it was available.
The adjustable upper arms aren't necessarily made to shorten the arms; they're intended to make them adjustable- either shorter or longer. In my case I adjusted them to be longer than stock and to put my rear driveshaft in a broken-back configuration. The standard setup with a 6" lift would be to make them shorter so the driveshaft angles match in the 'normal' configuration of opposing equal angles- which is how I set up my rig when I first put on the lift. That's the beauty of adjustableness- you can change it later.
If you just cut the arms and insert the adjuster mechanism, you obviously make them longer- you have to remove some of the arm to make up for the added length of the adjuster and then some.
-Spike
Wow if you got the the rear pinion to face up into a broke back that's a bit much don't you think?? Lengthening the upper arms and pointing the rear pinion straight at the t-case makes the t-case u-joint take all the angle from the lift, meaning you NEED a double cardon drive shaft. From what you say you're past that point and I cannot see how your shaft is not wanting to spit its self out with two opposite angles.
Now shortening the upper arms would point the pinion down, matching the angle at the t-case, which makes sense to me. I think this is mainly what I'm after, since my rear drive shaft is really complaining after the lift.
Anyone else though notice their rear drive shaft out of phase by one spline?
Wow if you got the the rear pinion to face up into a broke back that's a bit much don't you think?? ...I cannot see how your shaft is not wanting to spit its self out with two opposite angles.
With the rear driveshaft in a broken-back config, the angles are less than when it's in a 'normal' config. As for 'spitting itself out', the front driveshaft is set up this way from the factory and seems to do well. :D
-Spike
bear80,
here are some nice articles on it
http://www.pirate4x4.com/tech/billavista/PR-shaft/index2.html
good link- http://trailer-bodybuilders.com/mag/trucks_every_shop_know/
"Having the driveline in phase is especially important if the driveline must operate with high u-joint operating angles. The higher the operating angle, the more vibration an out-of-phase driveline produces, Koedam said. How It Happens Koedam said that a problem occurs when mechanics remove the driveshaft by pulling it out of the slip yoke. By being off just one tooth, the driveline can vibrate. "We only allow the driveline to be out of phase by one degree," Koedam said. "If you are one tooth off, the driveline is out of phase by 22 1/2 degrees."
-Spike
Yep but the rear isn't intended for a broke back. I guess I would have to see it frist hand. I would also assume the broke back setup requires the shaft to be 90* out of phase, did you do this also?
Thanks FirstToy. I hadn't read that second link, good stuff in there.
Spike, after thinking it over some more, I guess if the upper arms can be lengthened enough to push the pinion up into a broke back that would work. But I'm curious why Toyota did this for the front with the shaft 90* out of phase and most readings still call for a broke back to be in phase.
The only thing that designates it as 'intended for a broke back' is the angles of the t-case and pinion. And yes, I did switch the phase of my rear driveshaft when I changed the angles. I couldn't find a definitive answer on that- even the driveshaft guy I had replace the tube and balance it didn't know, and he has a lot of experience- so I followed Toyota's lead and assembled it as the front driveshaft was when stock.
FWIW I have no vibes (nor did I with the lift and normal config) with the benefit that my pinion and driveshaft are a bit higher (out of the rocks) and working at lesser angles. Of course, my pinion is also further up from the oil sump, which may or may not be a concern. I have an oil slinger (normally found in the front diff) to be installed when my gears go in sometime this month.
-Spike
Mine is out 45 degrees (halfway between in-phase and out-of-phase), and I have a vib/grrr at 1800ish rpm. I know, not very scientific or definite, but I'll post up when I dig into it (eventually). The truck came to me lifted and with the shaft this way.
Apparently there isn't such a thing as a "driveshaft shop" in the eastern half of Canada.
Still anyone else notice their rear shaft not being exactly in phase?
Yep mine was a half tooth off. Vibrated like crazy with J springs on deceleration. Taller springs just made the vibration worse. I eventually just went with a DC shaft after replacing the u-joints in the old shaft helped get rid of the vibrations for only 3 minutes.
ArmyFJ also noticed his shaft being slightly out of phase, but questioned if it was messed with.
Anyone that hasn't messed with their rear shaft mind to take a look? I've got the feeling that the rear shafts came out of phase.
