I am trying to replace the window run channel in the right rear door, but I am stumped at how to remove the window. I did the front door with no problem, but the rear door window does not appear to have the two bolts that allow the window to be pulled out. I have the door pulled apart and would like to finish it ASAP so any help would be much appreciated.
BTW the front window was very very slow and would stall at times, but after replacing the rubber channel it moves quite quickly, it is pretty obvious once you compare the old channel to the new why this is the case. The old one is like a rock.
Thanks
Thanks
ahead of me. I have my front door trim all opened up and cant figure out how to get the window out, have ne tips? Next i will probably do the rears, so If you figure that out let me know also.
