rear discs
Medford, Oregon
I'm doing a rear disc conversion and need some info. I did a search but couldn't find what i was looking for. What hose/banjo fitting is needed (the size on each end so I can have one made) I have the brackets, loaded calipers and rotors, what else is needed. Thanks in advance.
GM discs?
IMO, don't get a custom hose made...instead, re-flare the hard line and run the stock monte hose.
Tear a hose off someday and a custom replacement will be a PITA...Monte hoses are $9 and stocked everywhere....
Look in the technical link section and scroll down to where they list brake mods. I followed the directions in Chris Scullys article and it went great. He even lists what parts are needed. I really liked that I didn't have to remove the axles to get the backing plates off. If you don't plan on using them again a sawsall sure comes in handy.
NAPA carries a hose that will connect the cruiser brake line to the monte caliper.
brake lines
Look at tech again. I got the part number for a Raybestos hose that is SAE male on one end and Metric female on the other. This worked great, or like Gumby said, cut off your stock lines ends and put SAE on them, and put em straight into the Monte hose. Hodag
