Anybody know the torque for the cover plate?.....my gear oil is looking pretty yucky so I may need to remove and drain. I do have to torque this correctly right? TIA for your help!
remember to crack the fill plug before you do anything.
Important to get that fill plug open before DRAINING the contents of your diffy. Sure would suck to not be able to fill it back up again.....
I have this problem with the fill plug in the rear diff on my FJ62. I need to tackle that . I did pick up the allen head plugs from Toyota so it's won't be a problem once I get it off. Do the allen head plugs work on all years of the 40/55 series? I know the hex part is a lot deeper on the early 40/55 series but still a good upgrade.![]()
No, no, no, open the fill plug first, then open the drain plug to drain. You shouldn't need to touch the rear cover bolts.
I think I got confused....the drain plug faces the back of the rig? I'm not sure I've found another plug in the rear diff---
Thanks Charles....I will look for this drain...under there yesterday and have not noticed it![]()
Just a side note, depending on how dirty your axle is or how often you drag it over clay it may just be really dirty. I had to dig out my drain plug the last time I redid my rear axle seal.
