rear diff rebuid fj40
Point lowley
hi I have shattered my pinion bearing and theres a heap of movement in the spider gears I think its called in rear diff on my fj 40 im pretty sure its not the original diff center I have got a 60 series center or so I am told not to sure either limited slip and housing I have stripped the bearings and seals off it and its missing the pinion gear nut . I want to know if I can get parts to make this fit or where could I find a new center and housing I am moving house and need to get it back on the road asap any ideas ?>
I have measured the original and the spare they are both 180mm wide the origal bearing surface is 45mm and spare is 50mm both housings are 10 hole same dia if that helps I also have bearing numbers I will get once I get home
