Rear diff fill plug problem
East York, Canada
Today I went to change the gear oil in the rear diff. Problem is that I couldn't loosen the fill plug on the diff housing. I tried a sockeet with a pipe for leverage, a 24mm wrench which rounded the nut!! So I tried vice grips and a pipe wrench. I even tried heating it up with a torch. Didn't even budge.....
My 80 is a 93 with the factory locking diffs. I also noticed that the diff doesn't have a removable cover like my 87 HJ60 has.
Does anyone have any suggestions as to how I can remove the fill plug?
Good thing I didn't drain the fluid before seeing if I could loosen the fill plug!!
weld a good nut onto it.
the front diffs never had a removable cover since you dont' have to get inside to pull the diff apart before pulling the rear axles. earlier 80s had semi floater rear ends (like the 40/50/60 series) which require pulling a shaft and removing c clips to get the axles out, while later models (and non us) have full floaters which don''t have that issue and don't have removable diff covers.
I had that problem before. My plug was aluminum like the one pictured in the "read this thread" after being removed with a chisel. Could not weld aluminum. I drilled and tapped about a 3/8" bolt hole in the center of the plug. I then used a bolt with a flat washer and a round rubber bushing to help seal it. Works fine, just doesn't have the big hole for filling faster.
Probably not much help now if its rounded badly, but when I noticed that happening (on both the front and rear diff fill plugs on my '94), I ditched the 12-pt socket and reached for the 6-pt impact socket and let the impact driver hammer them off. I had a 24" pipe on an 18" breaker bar and the normal socket just rounded off the corners.
I read the link on removing the fill plug and have done everything that was suggested except for welding a nut onto the damaged plug. As I don't have a welder or access to one, I'm out of luck on that one....
Just wondering though how much pounding you can do on the differential housing before it starts to dent or damage?
The cover isn't that thick, but you can get pretty medieval before caving it in.:hillbilly: The plug should have a soft alloy sealing ring, when the plug hammered on, the ring collapses, loosening the fastener. Pounding straight in on the plug is best.
IIRC, there is a standard size that fits tighter (15/16"?) sometimes needs to be tapped/hammered on. Most sockets have a chamfer on the inside, with a short hex fastener like this, it tends to round, push the socket off. I have shortened them in the lathe to make a sharp edge, a grinder, belt sander, etc, would work. The best bet is to beg/barrow/steal an impact, I have never been denied with a good impact and socket.
How are you pounding the bolt? Are you using the chisel and pounding it as pictured in that ' stripped Diff (fill) bolt ' link. Note the notch where the chisel have dug in.... work a notch with the chisel into the bolt and pound the chisel towards loosening the bolt. It's nice if you have an air tool that can be equipped with the chisel. good luck...
