Sounds like your stock breather is clogged. Take it back off and soak it in solvent or cleaner so it "breaths". Or put the new Marlin one on. If it can't breath, it builds up pressure. If neglected it will push the gear oil out through your wheel bearing seals. While you're at it, check your front diff breather if you have 4x4. Simple to do and pays off in the long run.
Edit: Sorry-my bad-- just re-read your posts. You may be able to salvage the TG breather by cleaning it.
