Rear cargo light install (Help)
Spokane, WA
So I finished installing my rear cargo light taking advantage of the pre wired connection in my 93. I tested the light (made sure that I flipped the wires as stated in several threads on the original connector) as I worked through the process of recessing the back side roof behind the head liner and everything worked then.
When I fed the wires through I barely had enough to connect and pulled every bit of slack out. Now that it is installed the light is not working and now neither are any of the other interior dome lights, also the ring around the ignition is not lighting up... I obviously F'ed something up. Hoping someone will tell me its just a fuse and where to locate and not that I pulled all the wiring loose...please help, thanks!
Ok, definitely a blown fuse but when I replace it (x2) it blows as I am putting it in... whats next?
I have PFRAN LEDS in my front and two middle domes, was planning one in the rear cargo area, I also spliced in and ran wire to back hatch for an additional light down the road... but all of these worked before final installation... any help appreciated as I am not the wiring genius that I wish I was.
What was it? Can someone else easily make the same mistake?
Wearsabrowncoat I am thinking that jeffro's assumption was correct. I went back to the rear cargo light that I had just installed assuming that was the cause of the continued popped fuses. Because I had such little room to make the connection with the existing wire connector (94 and below, I think) I was worried that the wires were being cut into by the sharp metal edge from the recessed cut out. I wrapped the wires with electric tape and I also placed tape around the metal edges of the cut out. Lastly I had originally drilled my screws through the headliner material, I was worried this wasn't providing a strong enough ground so while I had the dome light out I also cut away excess headliner material to improve the ground contact.
Replaced the fuse and everything worked. Hope this helps if someone runs into the same problem, sorry that I am not more electronically proficient to better explain what had occurred. I basically just kept troubleshooting till it worked... And tried to stay patient! :bang::beer::bang:
