Rear Bumper Done....
back from powder coater.... had to made a few changes after I got it back from the powder coater though....
cut off the hi lift mounts.... dont need them. would rather carry it inside. Luke welded 1 on the tire carrier and 1 on the ladder....
added a lock pin to the tire clover shaft. Dont want that thing moving...
tack welded the ladder and tire carrier in place. I wont use any other accessory and I can always cut the tacks off if needed. wanted them a little sturdier than with just the bolts.
had to grind down the area under the shock slightly to get the swing arms to swing without slightly sliding on the top bumper surface.
Have some color matching touch up from the powder coater and will blend in those repairs.
Nice job!
I'm just finishing mine up this week. It's a fun project, huh? I like the extra bolt you added to the tire carrier.
I plan to have mine powder coated also. What kind of prep work did you need to do before it went to the coaters? Did it need to be media blasted? Did all of the welding slag and minor surface rust need to be removed? How about the finish? Did the coating fill in any minor flap disk marks?
Thanks for sharing.
the place I took it to, blasted it with silicon before powder coating. it did cover a lot of the flapper marks. the media blasting took care of the rust
I don't think it should hurt anything driving without the bumper removed as long as you aren't wheeling/flexing. I noticed that even in a driveway gutter that the frame horns move a fair amount, so wheeling would definitely add some unnecessary flex to the body/frame. I had mine off for a few weeks while I waited for it to ship.
powder coated mickey thompson's
