Rear brakes question
Saratoga Lake, NY
Rear brake removel question
I want to pull off the rear disks. What bolts are used to screw into the drum to pull it? The manual refers to "matchmarks". Do I use the bolts from the calipers?
my rear drums are easy to pull off by hand everytime i service the emergency brakes. just give it a light tap with a block of wood to help it loosen off while pulling. i think i saw the size of bolt you could use on the drum at the FAQ
Thanks. I just sprayed the poop out of the e brake parts from behind the drum and they losened up. We'll see how long it lasts this time. Reading the manual it looked like it was gonna be a chore. I need a lift in my garage!
