Rear pads replaced:
- Disable EPB: push parking brake down x2, then hold on third push. EPB deactivated; displayed.
- Disconnect parking brake connector on caliper. Apply 12v as on photo with positive on the right side to retract EPB then push the piston in with whatever tool you normally use
- Replace pads and shims
- Take note: the inner shim is wider (see photo)
- Caliper bolts torque 41ftlb
- Connect EPB connector, activate EPB: pull up parking brake x2 and long pull on 3rd
- Clear DTC codes. I used a Launch OBD reader. all worked
[td]
Part No.: 04466-60191
PAD KIT, DISC BRAKE
Part No.: 04946-60150
SHIM KIT, ANTI SQUEA
[/td]PAD KIT, DISC BRAKE
