Rear brake lines identification real time help
Pegram, TN
Hey all, lost brakes due to corrosion on the brake lines around the gas tank. I am running new lines from the valve to a spot on the frame right around the rear driver side door and will splice into the existing lines there. I cut and removed the old lines without noting which is which. Can someone tell me if the upper line on the frame goes into the upper port on the valve or do they switch somewhere along the line? Dumb question, I'm guessing, but I don't want to get it wrong.
Thanks!
can someone look?
Just got home - do you still need this info? I don't know that my '96 will match your truck, but I'll go look if you still need it.
That would be very very helpful. Thank you!
Anyone? Bueller?
