Thanks. My understanding was that the bleeding protocol cleared an airlock in the abs actuator. Maybe I haven't then held the pedal down long enough to get fluid through to the brake. Doing it solo so could be over cautious.Not sure what you mean with Techstream bleeding protocol, but the utility in Techstream for bleeding brakes is only for the abs-portion of the system, not for the actual wheel cylinders. You still have to bleed the four corners normally, several times.
The rears are very easy on the 100 with the electric booster, you just jam the pedal down (with a stick against the seat), and the fluid will flow continuously to the rears. Then you bleed each side until you got pure fluid flowing into your catch bottle. Just make sure you don't empty the reservoir.
