Rear bench installation question
Golden, CO
Anyone bolted a TJ seat in thier 40? Its a fold and tumble I picked up from troyintahoe and I need the mounting latch/bracket for the back side. Anyone have a part number or at least what it is callled. I have called 2 jeep dealers and they all can't get past the fact that its going in a toyota, "the latch should be on the floor....wait...what do you want? What year is your jeep? " They just don't get it.
Dan
Yeah, but should the rear be secured to the floor for safety sake? The belts will obviously be bolted to the floor.
On a TJ, the rear brackets for the seat also serve as the lower mounting point for the shoulder harnesses. The harness retractors reside on the rear upright of the roll cage. The belts are bolted to a plate in the center of the floor.
Imagine sitting in the passenger side of the rear seat. The 'fixed' bely piece is on your left side, you grab the shoulder/belt combo on your right side, and latch it. The belt on your right feeds down from the roll cage, through the lower bracket, and up to the latch. The shoulder harness feeds down from the retractor to the latch piece.
The lower bracket on the drivers side also has the latch mechanism for the rear seat to lock into, when it is in use. To fold-and-tumble it forward, you reach down behind the seat on the drivers side, pull up on a little lever, and the seat pivots forward, the pivot point is the front seat brackets.
This is all from memory, if you want to see it in person there are Jeep TJ's all over the place :eek:
haystax said:
So you stole my seat and you don't know how to put it in :flipoff2:
J/K :D
Well Geez!!! Golly if I had known it was you I would not have bought it from Troy. :D :flipoff2: :D
Just looking after the safety of my little guy who will get his first ride in the cruiser once I find that part. If I can't figure how to drill 4 holes and tighten the nuts up I'll be sure to call for some tips before getting on tech to ask for help :idea:
Its a nice seat, looking forward to getting it installed. :rub'n-it-in:
Desert Dave:
Are you referring to a front seat in your description of the latch? Seem like the rear bech should have some sort of plate that bolts to the floor with a simple hoop/ring that the sear latch locks into.
I'm pretty sure you should just need a loop or something for the latch to catch, correct??
If you want to sell me the seat I'll post pics of how I did it :D
You're probably running your own belts, not necessarily TJ factory belts :confused:
How about I'll let you look at the seat and I'll only charge you a the loop I need as the price for your personal R&D:D
Thats a good point. I was thinking about it on the way home and realized I really only need some type of loop or ring to make it work. Looks like I'll be roaming the isles of home depot and Ace to see what they have that may work.
Own belts. At least the ones troy threw in with the deal.
