Rear Bed Removal Advice
I am have been trying to clean up the underside of the rear bed on my 76FJ40 and it is killing me...the rear quarters and wheel wells are already removed and now I want to remove the rear bed so I can realy get the underside cleaned yup. Thankfully on two rust areas to weld in new metel (which is why I wanted to leave it place to begin with. In cleaning the underside, I found that the square support that runs cross ways behing the dricers/passenger compartment has some rust (see pic).
Options to remove rear bed, as I see it, are:
1. Cut along the seam where the rear bed meets the drivers/passenger floor pan; or
2. Drill out all of the spot welds.
Any thoughts are appreciated....ds
Drill out the spot welds, get one of the spotweld cutter drill bits from your local parts store. This approach will take a bit longer but is much cleaner.
You can take the whole rear from the back of the door pillar rearward as one assembly. Two 1 inch welds to cut through on both sides and a few 10mm bolts. Then you have to go underneath and drill out the spot welds on the seam. The body will split in half. I did this to repair the channel in you picture that was rusted out. the channel is actually part of the rear bed structure.
