Rear Axle Service
Hayward, Ca.
Well today I went to my father's house and decided to do a lil work on the ol' rig.. We were sitting around not doing anything constructive so I mentioned to my dad that I had been wanting to do a full service on the rear axle of my 93. I had all the seals, bearings, moly grease in my rear drawer, so we were good to go (it was all planned out to get my dad to help!:D Although, I did all work...:rolleyes:). I have done lots of front axle service jobs on lots of different cruisers, fj80's, fzj's, 40's, 60's, but I have never really fully serviced a full floater axle..I have however taken apart semi floating axles from both my sister's 92 80 and my old 78 40.. In this case, I had already swapped out the axles for my 93 to Poly Performance Axles, but didn't fully service the axle at the time (change small oil seal on spindle, inner hub seal, and grease up the 2 bearings along with the hub).. So I decided that I wanted to tackle this small job as soon as I had a free day. It was a really straight forward job, took about 4 hours max for both sides, and it was fun for the most part. I actually spent a decent amount of the tme making my own SST to adjust the preload on the lock nut for the bearings. I searched in the faq's and noticed a thread were others in this board have come up with their own SST, so I decided to do this too. I took a socket (forgot what size..) and notched 3 cuts on the outer lip of the socket and it worked perfectly ( thanks mud community once again for ideas). I did take a couple pics of the job. I decided not to take step by step pics because I figured there are how to service rear axle threads already here in the faq section.. So I will share a couple pics...Thanks for reading, and thanks to all contributors here on mud!:cheers:
Here is were our lil' project took place... The burgandy cruiser is the my dad's cruiser which we just finised the headgasket r&r, ome, 35's, fr axle r&r....Rear axle r&r next.......
Fast forward.......Once the hub got cleaned, greased up, got a new inner hub seal, it was time to reinstall on the spindle..
This was the socket we cut up to make our SST tool (I confess, my dad rigged up the SST tool..thanks pops!) Torquing to 43 ft lbs.....
Pic of the Poly performance axles..Getting these pesky cone washers was the biggest PITA during the whole job for me..It is easy if you give it a couple hard smacks with a heavy hammer, but you have to be careful not to dent up the outside lip of axle as some areas seem kinda thin...I used a brass hammer and a piece of wood...Took a good 5 mins. of non stop smacks...Don't give up, they will eventually come out....
Peace!
Moly grease in the wheel bearings? Moly isn't bad for the bearings but usally moly grease is "creamier" than the typical thick wheel bearing grease.
So where are those 36" bias Iroks??!!
FYI, the crappy multi-tabbed 4wheel drive loaner socket from autozone works very well on the rear. I know it can be used on the front (what I usally use) and it sucks but it really does the trick on the rear. The tabs engage the 3 round tabs of the lock nut really well, tightens right up and sets the bearing pre-load well.
Ben, I got a good deal on 35" bfg at's, so I gave the bfg km's to my dad (for his burgandy cruiser) and now I use the Iroks for off road only..These rigs feel a lot better with a/t's on the road..Reminds me even if for a moment, when the cruiser was all stock;)....Thanks for the autozone part info...I will look into it, although the ghetto rigged SST we came up with works great...
Ben here is a couple ones...Only ones I have....
