rear axle service problem
Gilbert, AZ
Hey everybody,
I am having an issue with my rear axle service.
When I put the rear axle shafts back in they stopped about 5mm short of home. I tapped them on the end with hammer and they went in 3mm more. I figured the rest of gap would suck back in when I put the nuts back on and torqued them down. No such luck.
When I look down on the end of the axle I think I can see space on both sides of the paper gasket, very little space, but enough to think that its a problem.
I put in new races and bearings, and believe I have the races fully seated.
I am using mobile 1 synthetic grease.
My truck has factory lockers and I locked the rear before I pulled the shafts, and it is still locked.
Any ideas?
Thanks,
Greg
It sounds like you have the axle positioned wrong, there are 4 holes in the axle shaft flange, two for dowel pins and 2 are threaded for screwes to pull the axle shaft I'm guessing your trying to force the dowel pins on the rear hub through the threaded holes
Pretty sure I got them lined up but will look when I get home.
Did you figure this out? I'm having the same problem.
Got it! Was only off by part of a spline. Once I pulled the shaft back out, wiggled the disc to rotate the assembly slightly, it went in smooth.
My problem was poor eyesight. The gap I was "seeing" was shadow.
I put on my reading glasses, broke out a strong LED flash light, and there was no gap. Tried to slide in an sheet of paper and there was no where for it to go.
