rear axle removal ..HELP ?
FWIW, I went to the Home Depot this morning and purchased a 4 lb. BFH and a 6" extension for a 1/2" impact wrench. 15-20 hits later, the pinion shaft was out. I almost gave up because it did not feel like I was making any progress. Then, all of a sudden, it gave way and I smiled.
hey guys i got the pinion shaft out without drilling, i did it with a normal sized hammer, an estwing, and smacked the crap out of the shaft until the 12mm bolt snapped. I of course had the housing out from under the truck, but i smacked one side until it gave a lil, turned it around and hit the other side until it recessed, and repeated numerous times and then focused on the side closest to pin and smacked it good many times using a 1/2" extension as a drift. Then, pulled the whole assembly out, and the cruiser gods must have been on my side, cuz just one smack with a nail punch, the rest of the bolt left in the housing flew out. Then i went to the pinion shaft and did the same to get out that portion of the bolt. then drilled out the remainder of the bolt from the aft region of the housing . So the bolt came out in 1, 2, 3 parts and a bunch of shavings. Now i am wondering where to order than bolt and maybe a new pinion shaft, since one side it is a lil rounded where it should be blocked. Should that be something to make me replace the pinion shaft? and where to get the shaft and the bolt? can i find one at the local hardware store?
As long as a new pin fits snugly into the pinion shaft, I would only replace the pin. I got mine, along with a few parts I have been needing from Spector (sor.com). I would have gotten it from Cool Cruisers, but they did not have a few of the parts I needed.
