rear axle leak
Not being a professional DIY'er, I have just enough knowledge to get myself in trouble most of the time. Here's the latest. Working on my '69 FJ40 I finally realized I needed new brakes, cylinders, etc (all stock). Noted oil residue in drums in previous adventures, this time is really bad. It is not brake fluid and can only conclude it is rear diff oil. In doing research into this I thought initially about changing just the axle shaft seals on both sides. SOR recommends changing C clips, cover gasket, bearings, pins, etc all for just over $ 100. My question is this, do I need all this while I have it apart or just replace the seals for less than $ 20 and go ? Also, I have never popped the cover on a diff before and a little concerned about what I'm getting into, such as shims, settings, etc. I am good at tearing apart and tearing up but sometimes getting back together is the issue, any advice ? Any special tools needed ?
Thanks
Welcome, DO you know for sure its gear oil and not a leaking wheel cylinder?
If gear oil is infact leaking out of the end of the housing then yeah new seals are in order. To change the seals you have to pull the axle shafts after removing the brakes. In order to pull the axle shafts you need to pop the dif cover and pull the C clips. that is how it is set up.
That said if you have gone through all the trouble to pull the parts. You might as well replace all of the other stuff, Bearings, diff cover gasket. etc. while you are in there. Its a bigger pain in the ass to replace the seals, and ten miles down the road the bearing fails. Your back to square one since seals are a one time deal. You might as well have the drums turned if needed and go with new brake shoes. Esspecially if gear oil is leaking on them, It will turn them to mush.
It is really not that difficult. I tore my first rear axle down a few months ago. It was not that bad. Most on here will tell you to junk the drum brake stuff and go with disks. Unless you have disk brakes in front already by a prior swap, I would stick with the drum stuff.
The only special tools I would recommend are a seal puller, Sears for like 15 bucks. and borrow a slide puller for the rear bearings.
You are not messing at all with the 3rd member, (Ring and Pinion) set up so you do not need to worry about shims, preload etc.
Hope it helps.
The haynes manual was pretty helpful for this rear tear down.
Thanks Guys
Got into the diff this afternoon and actually was not difficult. Just needed a shot of confidence. Bearings look good, bearing surface of axles show no scoring, so I plan to replace seals and have fun wheeling. Am replacing the brake shoes all around since I have it jacked up, Thanks.... :cool:
