Rear Axle Help
Santa Monica, CA
Website
www.elirubelphotography.com
this is probably a really stupid question, but I have never put together a rear axle, so if you guys could look at the pic of what ive done sofar...I think that there are supposed to be some sort of washers behind the spider gears that the big pin holds in place...maybe not...maybe they are allready in there? The reason why I ask is because it seems like the "block" thing that goes around the pin, has about 1cm (maybe less) of play (up and down along the pin) which seems not right.... thanks for the help
Eli
mine dont have any slack at all up or down,but the block in mine from side to side is so tight it will not allow to move either direction.thats why i ask if you but the shims in,but my last third did have a little slack no harm so i figure you should be ok.you will know pretty quick when you go to drive it if you did anything wrong:beer:
This is funny because I am working on the same project today. Putting 75' axle shafts into my 67' axles.
Yes mine has thin cupped washers under the spyder gears. Check the gap between the end of the shaft and the pinion shaft spacer. The gap should be between 0.0024" and 0.0181". If not you can get the cupped washers in three diferent sizes. Good luck
