Rear Axle help please
Fort Wayne, IN
For the past few months I have been chasing suspension noise. After checking for loose bolts, transmission mounts, etc. I have located the culprit. While having a friend grab my bull bar and start rocking my truck I narrowed down the noise to the short side rear axle. After reading the FAQ section of rear axle rebuild I decided to try fixing it myself. I was planning on calling CDAN on Tuesday to order parts and the SST to remove the axle nut. I started on the project today and to my surprise.. I was able to remove the axle bearing lock nut with my fingers.... way to loose. Apparently after having my 488 gears installed 30,000 miles ago the lock nut was insufficently torqued sp??.:doh: or can they become loose on there own? I doubt it.. OK on to my question.. Will I still need to order the SST to sufficently retorque the axle nut after installing my new parts?
You need to get it apart and get a good look. My guess is that it was not reassembled right, as there is no way for the rear to come loose. The reason is that the rear lock nut is tightened down, and then 2 small screws are used to firmly anchor it to the thrust washer, which has a tooth that prevents the whole assembly from turning.
You don't need the sst. I have tensioned mine previously with a brass drift to one of the protrusions of the lock nut. The sst does make it easier.
Once you have the bearing pre-load set right, you line up one of the protrusions with a scribed line on the spindle, then set the lock screws in a hole at 90 degrees. You really have to have the FSM or have someone show you or it will never make sense. Very easy to do though.
If the wheel bearings have been run loose enough to make a noise, I would inspect the bearing very carefully for damage, and the spindle as well. Good luck, those spindles are not replaceable.
Thats the info I needed. I have everything apart and it all looks good. The noise or feeling I had was like something was loose on a side to side motion. Maybe described as a clunk-clunk. Yes.. I am a member of the writers guild. NOT. Anyway the axle nut not being tight enough explains everything. I am cleaning everything up, packing the bearings, etc and giving it a go. THanks.
