Drained the oil, remover pinion shaft, washer ect, removed clips, one axle which has the brake drum removed slid out fine...Now, the other I could not remove the brake drum as the retainings screw is rusted/stripped and the two bolt holes that can be used to back off the drum are rusted...and now stripped....So I thought I could remove the whole axle and brake drum together and then separate everything ...if anyone sees a wrong here please give me a heads up. Right now nothing is moving and this I think is due to the brake shoes sticking against the drum...how do I back off the shoes??? Some one mentioned there should be an ajuster on the inside of the ..axle flange?? but unsure exactly where.
Thanks
J
Thanks
J
