rear aussie locker & Pin 7 mod observations
North Cadillac
had a chance to do the pin 7 mod before i went wheelin this past weekend. Before doing the Pin 7 mod i have wheeled this same OHV park unlocked, rear aussie locked, and now rear aussie with pin 7.
Before the mod the rear would bind around turns while wheeling in L range. THe aussie was obviously locked thanks to the locked tcase.
Now, i was able to drive in low range with the CDL unlocked for great speed control and overall control without the binding of the rear. It would ratchet around turns instead of binding. When i would get to an obstacle, i could push the CDL button and it would lock up the aussie fully.
Great option if you have the Pin 7 and are thinking of a great, easy and cheap rear locker. :steer:
Just to make sure that folks don't get confused about the Aussie--
Engaging the CDL--in LOW or HIGH--does NOT lock an Aussie Locker in your rear axle. That may--or may not--be the net effect, but all the CDL does is lock the center diff. The Aussie WILL lock with the center diff open in low or high range, and it will unlock with the center diff locked as well.
The only functional fact of the Aussie Locker locking is torque applied through the rear drive shaft.
I think that your observations are revealing the nature turning with the center locked:
The torque is not equal at all four corners--some wheels are seeing net torque from the road (scrubbing), while others are pulling to catch up. I would guess that the the associated binding and understeer are requiring you to gas-it just a little more, making the rear lock-up.
With the center diff open, everything is smoother--and the extra torque is not needed--so you're less likely to lock-up the Aussie.
Regardless of the hows and whys--your observations match mine, and they are a good illustration of how the Aussie Locker works very well in an AWD 80-series.
How about an Aussie in the front? Could we expect the same 'good' behavior with the center diff open?
I couldnt find that particular thread, but here is one discussing it:
https://forum.ih8mud.com/80-series-tech/99616-front-diff-lock-question.html
when you need a front locker, you also need to be able to select when to turn it off. I was wheeling this weekend, and I was in several situations where I needed the front locker at one point, and a few seconds later, I needed it off because I had to make a sharp turn. I was so bound up that I seriously could not budget the steering wheel. Do not go auto locker up front. IMHO.
the aussie is not a good idea in the front axle IMHO. The aussie will lock up if enough torque is applied to it, it's just more difficult to do that with the CDL unlocked.
to get the rear aussie to lock up with the CDL off, you really have to give it a lot of skinny pedal.
Again, i'm NOT saying the aussie is a selectable locker like the OEM or ARB lockers. I am saying there is some amount of controlling it with the CDL, some amount.
