rear 3rd compatability
Bend, OR
Trying to find out if I can put in a rear 3rd from a 93-97 FF non-locked in to mine 91 SF. I'm running stock gears obviously...
I'm ignorant on how the FF axles are in the third? C-clips?
AFAIK the 3rds have nothing to do with either FF or SF. I would think it bolts right in.
FF axle shafts are not secured to the diff by c-clips. The axle shafts are bolted to a hub on the outside of the housing and are easily removable, even with the vehicle on the ground. Hence the term "full floater".
Thanks, I had a vague idea of what a FF was about. Just no sure about the 3rd member part of it.
So it would seem that they should be interchangable as long as they aren't locked.
I mean thinking about it the ring gear, carrier, and mounting pattern SHOULD be the same. I was hung up on the side and spider gear maybe being different because of the axels....
