Real time starter rebuild
Knoxville, TN
SO I am trying to get the damn thing out of the truck, and come to find out my impact wrench doesn't seem to be working quite hard enough. Maxed out (120 psi or something like that) I can get the the rear bolt bolt to budge, it has even been sprayed with liquid wrench.
Any thoughts? Do I need to go rent a "real" compressor from Home Depot or something like that? Is there something special with that bolt?
Thanks
Sean
You shouldn't need an impact wrench for the starter.
An air ratchet might not have enough torque, but I have always taken those off with a set of basic hand tools and an assortment of extensions.
Give the liquid wrench some time if things look rusty
Frustration
I can see the bolts just fine, but can't get any sort of leverage on either one. That is why I borrowed the impact wrench and compressor. However even the impact wrench will not break it loose.
If only you lived in North Texas I would gladly buy you beer and pizza to help me get this thing out and rebuilt.
Sean
I did this without any air tools at all and it wasn't too bad really. I seem to recall using my cheater bar and there being some cursing at least for a short time. Once you get the right ratchet / extension / flexy thing together, put a pipe or some other cheater bar for leverage on the wrench and have at it. You could also use some heat in combination with the liquid wrench (I've heard PB Blaster is better), but I think once you get a cheater bar on there you'll be fine, although it's slow going due to the range of motion you will get with the cheater until the bolt is loose enough to move it without the cheater. Good luck.
Mine was a b@#$% to get out too, the only way I got it out was to use a bunch of extensions and a big breaker bar. A good shot of some PB Blaster helped me too.
Stay with it, you will get it. The rebuild is very easy, that was the easiest part of the whole thing!
Daisy
yep, just used a 3/8 ratchet + extension bar for leverage. from what i remember, you may need a socket extension. for the front bolt, get right in the wheel well, ratchet extension on top of your right shoulder, then just muscle it up slowly. the rear is easier as you can get at it from under the DS door.
Huzzah!
I finally got that son of a bleep out of the truck! Ditched the impact wrench, found out the compressor didn't have the ballz to drive the wrench hence why it wasn't working. Through a combination of different sized extensions and a 4 foot piece of pipe I got it out. Going to rebuild tonight after dinner and put back in. Now that I know the trick putting it back in should be a breeze. Thanks for all the help guys/gals!
Sean
Haha, man, i can totally understand your feelings! It's easy to get a little pissed at times. Seems like every project i do to the 80, there is one bolt that will either strip, break, round off, ect... ALWAYS!
Just take a step back, calm down, drink a cool one and have a look at it again.
Now that you have removed it, you will be able to do it a lot quicker next time in a few months. :)
Cheater bar beats air wrench many times. 4 foot extension with 80 lbs of force equals 320lbs-ft.
DougM
Bit late for your stuck bolt, but here is my write up, it may help others.
All done from wheel arch.
Removed front wheel (starter side) pull off the rubber water guard, remove auto box dip stick, undo the two screws that hold the auto box dip stick in place, one on inlet manifold and other just below starter motor, leave the two small hoses connected! then just pull upper out of the lower half of the dip stick and move to one side and push a small bit of tissue into the lower half of dipstick to stop debris entering the auto sump.
Remove the + terminal off the battery, then remove the two connections on starter motor, one is a push connector and the other is secured with a nut and washer.
Remove the two bolts that secure the motor to the bell housing, I used a 17mm open/ring combination spanner/wrench, I put the ring end on the bolt head and used a 19mm ring spanner/wrench on the end of the 17mm so to use as leverage, sounds confusing if you have never done this, but just put the ring end of a spanner/wrench on the open end of a spanner and try it, it works great, (photo attached) then remove motor out through the wheel arch area.
Then just remove the plate/cover which is held with three small screws, the rest is quite easy, just remove the contacts and replace as they were removed, just before you fully tighten the contactor bolts, gently tap down the contacts so they are flush with the inner of the plunger housing, flat/level.
Replacement of the starter is just the reverse of removal.
Like I say all can be done from the wheel arch area, it really is quite a simple job to do.
Tools needed are....
10mm spanner to remove batt terminals.
12mm to remove auto box dip stick tube.
17mm open ring plus 19mm open ring (leverage spanner) for starter housing bolts.
14mm ring spanner for terminal nuts.
8mm ring spanner for contactor cover
It's probably better to purchase a new plunger as well as the contacts, as this wears too, but I just rubbed flat with emery paper, but if I had known, I would have replaced plunger too, if it plays up again, I will replace all parts.
Argh
I knew I forgot something, didn't re-attach the tranny dipstick tube to the manifold. That is a no brainer so i will work that one this weekend, it's not going anywhere.
