while replacing gaskets i took my edelbrock intake off and the distributor was off as well however i did mark the intake manifold and dist. bracket and i know that didn't move a bit. now i'm onto replacing the dist. wires and i have the engine at TDC from the mark on the main pulley but the rotor is pointing 180 degress away from cylinder one. i'm pretty sure that if its at TDC the rotor should be pointing at cylinder number one but its pointing 180 degrees away from it?
should i start to install my spark plug wires and assume that the plug wire its pointing to is number one or have a 180'd something while reinstalling it?
