(Real time) Rock Sliders
Red Deer ,AB,Canada
Website
www.cardomain.com
Working up In Conklin Alberta right now and have to keep a welder busy, I was going to get him to make me some sliders out of 2X3 tubing and use 2X2 Tubing mount to the frame . I need the measurement from the back of the front fender to the front of the back wheel well. Also the measurement from the frame to the out side of the tube . ASAP I want this welder to look busy while he is making his 120 $$$ an hour :D . Thank you
I can't help you on the first because my rear wells are hacked, and I need more clarification on the second. Frame to the outside of the tub where? behind the front door? To the edge of the running boards? If you're removing the running boards, that measurement will change as the tub narrows along the rocker panel as you move from just behind the door to the front fender.
tcarlson4.webp looking too do something like this just want the sliders closer the the body
From the rear of the front fender to the seam where the quarter starts to curve up is 42" and from the frame to the outside of the sheetmetal where the rocker bolts on is 13"
Here is a pic of where I measured....
HTH
Just behind the behind the front door - 14"
front of the front door (just behind the body mount outrigger) - 13"
just in front that body mount, at the edge of the front fender - 12 3/4"
I only checked the pass. side, but they should be the same, right?
Degnol, you got 13" frame to body at the rear of the front door?
I only measured in one place......ASSuME-ing it was the same.:doh:
Ed
Ed
Yeah, but I think you and I got different measurements at the same point.
No, my pic was to show where I took the length measurement.
Ed
