Real time: rear tcase bracket
Tucson / Vail, AZ
Website
kartchcustoms.com
Help! I've put my tranny/tcase in place and am now ready to put on the rear mounting bracket that goes on the back of the tcase.
In the manual it shows a "C" shaped mount that goes around the cone shaped cover. My mount is a full circle and will not fit over the cone shaped cover.
Is this a stock mount? If so, how do I put it all together? The only thing I can thing of is sandwich the mount between the case cover and the cone cover. If I do that, I guess I need another gasket.
Any suggestions? Am I missing something?
It's a 79 FJ40 w/ SBC conversion. Stock 4 speed tcase/tranny
Azrocks said:
THe sheet metal cover goes on after the mount, and if ya' have time install studs instead of bolts.......any auto parts store should have them as they are a common import exhaust application use Silicone RTV on the outside
Butch
I am not aware of a C shaped bracket that is used on a stock truck to support the transfer case....if just hangs off the rear of the transmission....
Since you have a small block, your rear engine mount likely attaches to the rear of the tcase around the six bolt holes that should have studs installed in them to try and prevent that mount from loosening, and damaging the tcase casting....
If your trans output shaft hits that support/crossmember, you will need to either get a new one that AA sells, with the cone cover welded right to it, so that it will not leak, or, cut a hole in yours, and weld your cone cover to it...again, so it will not leak. :)
Good luck!
-Steve
Post up some pics for the hell of it....
Thanks all, I just wanted to make sure. The "C" type bracket I saw was in a picture in the FSM. That whole bracket deal sandwiching between the cover and the case seems pretty strange if you ask me, but hey, I'm not an engineer.
Thanks again, I really appreciate it.
