real time: Radiator removal
USA
any write up on this?
easy short cuts?
where to begin?:eek:
"Remove PS center bushing horizontal bolt thru the front of the grill (12mm - 8in extension with wobbly and 12mm socket while vice grip the bolt on the engine side)"
What is this?
"- Remove 12mm long vertical bolt from PS only (you are going to leave the DS frame in the truck and pull the PS frame out with the rad). Move the PS frame toward the rear of the truck, and remove/install."
And what is this?
Never mind guys....I got it out and a $180 dollar replacement going in....
What should have been a 2 hr job turned into a whole day, Oh well....
Don't look at it like that; look at it like this ... the NEXT time you do this it'll take you less than 2hrs! That's the cool thing about wrenching and learning. Anyways, :cheers: for the work!!! :cheers:
