Real Time: Locked brakes
San Elijo Hills, CA
I am just getting started on new rotors and bearings and when I pulled off the wheel and unscrewed the screws holding in the caliper I am unable to remove the caliper because the brake is locked up on the rotor. Any suggestions? Thanks.
I ended up just removing the pads with channel locks and then taking off the caliper. Hopefully I will be able to get the pistons to retract so I can put the new pads in.
you should be able to spread the pads. When I checked my pre-load, I used a pair of channel locks to push the pads in a bit.
Anytime you push the pistons back into the caliper in order to get room to fit the new, thicker pads, don't forget to loosen the bleed screw and let the old fluid bleed out while you do this, rather than allow it to be pushed back up into the system.
This is critical if your truck has ABS, as the old, dirty, rusty fluid will ruin your ABS pump.
And it's good practice anyway, as you really don't want that old cruddy fluid in your master cylinder.
