Real time help
Yes, my truck was trapped in the garage.
The tire was completely flat. Driving it was not a good idea. I lifted the truck with the jack and filled up the tire with a Costco air compressor.
Then I drove off to the tire shop. The "core" of the air valve was loose, thus air was escaping. At the tire shop, they replaced the valve stem and we were good to go.
Thanks for all your help
Alvaro
Ah, I'm too late to recommend you hook the winch up to the house with a snatch block to a tree and move the garage wall 5 feet to the left.
DougM
can you believe he put the *floor* jack under the axle and still didn't move the truck by pulling on the jack until it's out of the garage...? or even better, get the engine running and push with the rear wheels... that would have been the classy thing to do IMHO... in the spirit of MUDdom :D
HELP!!! I pulled into the gas station on the passenger side and the nozzle won't reach! Real time help.
You're going to need to buy a dual dual filler neck from Tuvalu. Tuvalu requires that all gas caps be on the right hand side of the vehicle. So, Mr. T made a few thousand RH dual filler necks. All of them have it. Those with only one tank have a big rubber stopper shoved up into the 2nd tank's filler tube.
Unfortunately, of the 25 vehicles sold there, 23 are still on the road. So, there isn't much hope of getting one of these gems on the used market. Fortunately there is a guy down on the docks in NY who has a container with the rest of the couple thousand that Mr. T created at the start of production and didn't put in any vehicles since so few were selling.
Oh, and one of the requirements for having the RH fill spout is the center-run exhaust using the type 'C' muffler bearings. Without it, the fill tube runs precariously close to the exhaust pipe.
