Real Time Help!!
VA
My air bag light is on! What could it be? The light was on after getting it from the body shop. Nothing seems out of the ordinary. What can I do to make it cut off? Please help. 1996 L/C. Thanks!
Did they steal your air bag?
There is a big theft ring in Toronto that takes bags...one these dipsticks actually killed a policeman by running him over a couple of months ago.
http://www.citynews.ca/news/news_13394.aspx
Real Time Help...air Bag Light!!
Maybe more details about the body shop would be helpful here. Body shops "typically" are not terribly aware of the finer mechanical points of re-assembly after a repair.
It's not at all uncommon to leave a connector disconnected. Do you have a manual that shows the connectors? They are the yellow ones, likely one is simply left open. Look around the area of your repair to see if anything is obvious. Was anything removed that would necessitate the disconnecting of one? Otherwise, take it back and tell them about it, or find a way to read the airbag codes (can't remember how, it's been too long for me!).
Good luck, by the way, the airbag likely won't go off if you hit it in the front end, be careful out there.
Dan.
IIRC, on the 80 series anyway, isn't the light supposed to come on after 10 years to "initiate" a check of the system? Then that happens again every year or two thereafter?
Not saying this is the reason your lights are on and I can't remember for sure that the light really does come on after 10 years or if it is just the rule...Yeah, I know...Not a lot of help :)
It's the body shop's fault, so take it to them since you're not going to provide us any details (why did you cut and paste your post from 2 hours ago - exactly??). They did it. They fix it. Too many things they could have done for the problem to be solved here in reasonable time.
DougM
The airbag light came on in my 1996 LX450 over a year ago. Took it to the Toyota dealer and they said it was a bad sensor-$521 to replace. I've just learned to live with it being on since the guy said the airbags would work anyway.
The airbags won't work with the light on. The light indicates a fault the SRS system finds after it performs its self check each time you start the truck and disables itself if there's a problem.
DougM
Kino,
Be sure the following happens when you start your truck. First, the airbag light comes on for a few seconds, then turns off. If it never lights at all, you've got a dilemma. Should be fine, but the system can diagnose itself and if this does not happen then somethings up.
DougM
No and no.
-B-
No and no.
-B-
Thanks B...
Now you got me wondering what I read. Maybe it was just posts about the sticker on the visor mentioning that the airbag system needs to be inspected after 10 yrs and then every couple years thereafter...The good and bad of MUD...So much information to digest and sometimes it doesn't assimilate in my brain as well as it should :D
