real time help with belts.
Socal/ I.E.
I am changing my belts this morning and I am having a hard time getting the new belts on. I serched for some of the belt replacment threds I have seen in the past but had no luck. This is the third time I have done the belts so I know how to do it. I just need a trick to get the new belt on the pully.
Thanks
What belt on what pulley? Did you loosen the tensioner pulley (if it's the A/C belt) or the alternator adjuster (if the main pair of belts) all the way?
12mm flexhead gear wrenches help loosen the alternator tension bolt. loosen the ac pulley nut and access the tension bolt underneath through the hole in the skidplate. iirc the 2 alternator belts go on first. i get as much as i can on, then turn the crank pulley to fully seat them. the ac belt should have enough slack through the tensioner bolt to put it on. shouldnt take more than 30 minutes to do all 3...
Did you loosen the alternator pivot bolt first? It's the bigger one (14mm socket) at the top of the alternator where it attaches to the block. If you didn't, loosening the alternator tensioner won't do diddly for you, as the alternator won't be able to pivot down. Loosen that bolt a few turns and then push down on the alternator to get as much slack as possible.
Maybe you could just remove the top and bottom alternator mount bolts and just tip the alternator pulley in to the belts like in the alternator upgrade thread. Remove the battery positive wire first; that way the wiring should not have to be removed from the alternator.
In the end it may save time and sanity.
Bill
Are you sure you have the correct belt? I'm pretty sure there was plenty of slack once everything was loosened up the last time I did the belts on both 80's.
I got it! I had to put the belt on as much as I could inorder to provide tension on the altenator belt tensioner, this tension alowed me to loosen the tesioner some more. I also found that the first belt was a little smaller then the second. Enough that when I tightend the belts up the was about a 1/4" more slack on the front belt. I expect this to equal out as the belts wear in.
Are you using Toyota OEM? I wouldn't have expected this if so...
Dan.
Hawkeye,
I'm sure others are thinking this, but something's very very wrong if you have two fan belts with different sizes. If you could tell the difference by eye then it's a problem but if you can tell there's a difference on the truck it's even worse. Were these two belts handed to you by a Toyota parts person and were they secured together with a small bit of twine? That's the only way you'll get Toyota fan belts which are carefully matched at the factory and I'm thinking that's not what you got.
DougM
Yes, they are from the factory, OEM, tied with twine, and yes they were even handed to me by the parts guy at the local toyotasRus. You could not see a differiance when hoding the belts or even when the were in the package. But when the belts were installed and I was tietening them I noticed a small differiance.
Hmmm... Are you 100% certain that they're lying fully in the channel on the pulleys?
Is it possible that one of them has a 1/4 turn twist in it?
Have you turned the engine over once and checked again?
