Real time help wiper seals
MN physically, MI spiritually
Took off the wiper seals on the outside of the axle and of the two rubber seals with the groove one was grove in and one was grove out.
Someone please set me straight on which way the groove sits. Outward toward the tire or inward toward the center of the truck.
Thanks a ton.
Just clarifying, there should not be 2 rubber seals on the knuckle seal. Should be steel/rubber/felt. Not sure what you mean by groove, but on one side of the rubber seal there is a raised ridge and I'm 99% sure the ridge faces the felt seal and its purpose is to indent into the felt and thereby help keep the rubber seal from sliding around.
DougM
DougM
Right. The one on the dr side was raised edge out and the ps was raised edge in so I was confused. when I said two I meant one on each side. I put them both raised side in facing the felt after some thought as it made sense to keep the felt from moving.
Thanks for the input!
When I helped with FlyRod's, they ended up going on the same way they were in the packaging. Made it easy, as long as you didn't practice juggling with them or drop them.....
IIRC, the diagram in the FSM indicates the raised edge somehow if you look closely - just in case it is ever in doubt again.
DougM
