Found a few minutes today to get under my rig to grease the knuckles, got it done using Palladium 3% moly, took about 90 pumps (about 1/2 tube) from my 25 year old NAPA grease gun for each side (serviced the gun also before starting).
Here is the problem:
I always turn the steering wheel side to side to get at the fill plugs
by poking my head over the tires; works well for me.
After I turned the vehicle off the last time, I got the steering wheel/tires too far over to one side; now the key will not turn in the ignition switch; locked tighter than a tick on a ?? (what was that Jesse Ventura line in Predator?)
This has happened to me (?all of us) many times in the past, and always just a little pressure on the steering wheel in the direction the wheels are pointing releases the lock; not this time.
Put a lot of human generated torque on the steering wheel, more than ever before, still the ignition is locked. Tried going the other way, tried wiggling the shifter, checking that it is in park, etc,etc.
No go.
I have heard that by raising the front wheels off the ground may
take enough pressure off the steering column to allow it to unlock,
but, unfortunately, my 3 ton jack is at the other house.
Anyone have to tear into their steering column to fix this, and if so
any pointers, or other suggestions?
Thanks and standing by.
g
No go.
g
