Real Time Help: Starter Issues
Portland, Ore.
Currently the land cruiser is stranded in a parking lot. It started up fine twice this afternoon, but the third time I went to start it the dash lit up like usual, but only for a second and then went completely out, along with the lights and everything that takes power. I had my buddy give me a jump and it started up fine, but then I drove away to run another erand and tried to start it again (this is after it had been running for about half an hour) and same thing dash came on and then cut out and nothing works...
I an guessing it might be the alternator since the battery took a charge when jumped (and its an optima).
If it is the alternator can I fix it my self.. new alternator maybe..
I did a search and read something about replacing the brushes, will this fix the problem and how long does it take, or is it something more serious?
please help, I hate having to leave my baby stranded...
Have the battery load tested. How old is it?
A dead battery will exhibit the symptoms you describe and will take hours to recharge.
-B-
Sounds like a bad connection to me. Clean and tighten the battery terminals, and see if that takes care of it.....
the battery was red top optima that was 16 months old, I just got back from costco and exchanged it for a new yellow top.
I dont know i think it may still be the alternator that has the problem, is there any way to check?
