Been troubleshooting a sound that I have been hearing:
https://forum.ih8mud.com/80-series-tech/343272-introduction-some-troubleshooting.html
Well, its now become real-time... EDIT: Problem solved. Lower caliper bolt worked itself all the way out
Come to a stop sign and hear a huge pop and some grinding. Then its coasts and again with the pop and a tad of grinding. Pull over to inspect. Take a look and nothing really looks out of place or clearly damaged. Closer inspection of the front right rim shows a deep groove around the inside of the rim with metal shavings.
More testing:
Put in D, its moves forward a bit and meets total restistance
Put in revers, it moves back as far as I want
Put in nuetral, physically push it forward and backward as far as I want
Put in drive, it moves a bit and I meet total resistance. Give a tad of gas and it pushes through the resistance with a big pop and tad of grinding. It coasts just a tad and again with the resistance. Figures I shouldnt do that again.
Hit CDL in High, move forward a tad and it meets total resisitance... thought it might be the ABS
Not sure why I can push it forward but cannot drive it forward??
My plan to get it home 1 mile from my house: head over there with tools and first remove the ABS sensor (because its easy and maybe a "crazy" sensor?)... then test. Second, remove front DS and test. If that doesnt work call AAA, renew membership and get it home.
Any thougths? Maybe blown ujoint? Birf? Caliper/pad issue?
Today... I feel very thankful and lucky to have not been on the freeway with my 2 young ones in the car and have this thing grenade.
Thanks for any help!
More testing:
